×I need a JQL query so i can create a filter which will pull issues scheduled for the CURRENT Mon-Fri calendar week.
I've found the below query which works and pulls the LAST calendar week info of issues done for a particular team/board (NewsDNA Commercial Design):
project = "NewsDNA Commercial Design" AND resolved >= startOfWeek(-1) AND resolved < endOfWeek(-1)
But I also need one which will pull the CURRENT week's info. To clarify - the current week info can capture all resolved or active issues to be done/that are scheduled in for the week (so not just resolved or completed items).
HELP PLEASE!!
Welcome to the Community!!
Monday to Friday right?
Here it is :-)
due >= startOfWeek("+1d") AND due <= endOfWeek("-1d")
Please note this will return all issues that are due this week
You could start exploring dates by editing JQL in a basic format
Thank you! What about if the due date is still later than end of week, but is actually being worked on this current week...? This is the problem i'm having now with these later dates not pulling through.
Include only this part
due >= startOfWeek("+1d") AND updated >= startOfWeek("+1d")
to find out issues that have due date and updated issues from current week starting monday
Use time range and get comfortable with JQL Functions to dynamically adjust the weekly issues
Here's the doc
Pramodh
Are you using "due date" for this? If so then maybe the following will work for you.
project = "NewsDNA Commercial Design" AND duedate >= startOfWeek() AND duedate < endOfWeek()
thank you! I'm now having trouble pulling through any jobs that may have a later due date than the current week, but are actually being worked on IN the current week.... I'm not sure if this can ever be done without knowing exactly what jobs are scheduled in for the week and putting them in manually :(
Adding to Jack's suggestion: to also include the in-progress items which are due *after* this week, please try:
project = "NewsDNA Commercial Design" AND duedate >= startOfWeek() AND (duedate < endOfWeek() OR statusCategory = "In Progress") ORDER BY Key
Hi @Tarfon, Carla,
The key to what you are trying to achieve is in how you identify what is scheduled to be worked on in the current week.
The JQL queries shared by both @Pramodh M and @Jack Brickey show a correct way of searching for Jira issues. If you schedule issues to be worked on with another date custom field than due date, you could just replace due date with that other field.
As an alternative, you could also look at the way you plan work in Jira. If you set up a scrum board for scheduling, you could create sprints on e.g. weekly basis and add the items that should be worked on to them. JQL allows you to filter for all the issues in the active sprint like this:
sprint in OpenSprints()
An additional advantage would be that you can see all the active issues in one single view on that scrum board, without any further JQL being required. This would require considering the way you organise planning, but that is not necessarily a bad thing!
Hope this helps!
