I am creating an automation rule and doing an issue lookup with the following JQL
issue in linkedissues({{issue.key}}) and issueLinkType in ('parent story')
What I expect it to do was pull the issues that were linked to the issue with a parent story link type.
What it is doing is pulling the the issues linked to the issue then looking at those issues and seeing if they have a parent story link.
I put the query in the navigator with the same results.
issue in linkedissues("ISSUE-123") and issueLinkType in ('parent story')
For example
My issue ISSUE-123 has the following linked issues:
ISSUE-124 (parent story Link)
ISSUE-125 (relates to Link) This issue has a parent story link to ISSUE-111
ISSUE-126 (relates to link) No Parent story link.
The quesry is pulling all three issue.
I am adding a number field from the linked issues. In this case I would Only want it to look at ISSUE-124 but it is adding the value from ISSUE-124 and ISSUE-125 because they both have parent story links.
Any idea on how I can have it only pull the parent story link of the initial issue.
Jenifer
I believe that JQL is getting the superset of what you want: any issues linked to the target issue and which have any links of that type to any issue (not just the target one).
If you specifically want the issues of that type, linked to the target issue, please try this syntax:
issue IN linkedIssues("{{issue.key}}", "parent story")
https://support.atlassian.com/jira-software-cloud/docs/jql-functions/#linkedIssues--
Hi @Jenifer Kuntz so it's reading both clauses and returning true on both. I'd suggest you review using smart values here's a couple pages for your review. Hope this helps.
jira-automation-conditions
jira-smart-values-conditional-logic
Hi Craig, thank you for responding.
In my case, I need the issues to be in the Lookup Issues because I am using that in a calculation so needed it in a JQL. Bill's answer worked for me.
You should insert a branching action and branch on the "Parent" issue. That will allow you to pull the parent of the current ticket.
Hi Kian,
Thank you for responding.
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
