JQL automation for releases
Deleted user October 2, 2022
Hey im trying to create an automation that when i made a release it will update all tickets that are in QA ready and publish to marge to prod
but im getting this error
Error
  • The rule has been configured with components that require issues to be provided by the trigger. To run these components you must add a branch for this version or JQL. The following components require issues: Issue condition, Transition issue
what can i do?
Nic Brough -Adaptavist-
October 2, 2022
You need to do what it says - create a branch in the automation to run with the issues in that have the version the rule is supposed to be working with.,
October 2, 2022 edited
Hi @[deleted]
Adding to what Nic suggests...
Looking at your rule, you may see it is triggered on Version Released...and the rule does not know which issues are associated to that version.  That error message is describing that condition.
To resolve this, you may add either of these immediately after the rule's trigger:
  • add a Branch on JQL to find the issues matching fixVersion to that version released
  • add a Branch on issues in the version
After that your rule would look like...
  • trigger
  • branch
    • condition test
    • action to transition
Please note: if the issues you want to change *are not* in that released version, just use a JQL Branch to find them.
Register now
