I am using OAuth 2 to connect to the Jira API. I have followed the documentation. The authentication and API calls go through, but when running a search query, I see no results.
reqBody, _ := json.Marshal(map[string]interface{}{
"expand": []string{"names"},
"jql": `text ~ ` + request.Query + ` order by created DESC`,
u := jiraAPIBaseURL + "/ex/jira/" + resource.ID + "/rest/api/3/search"
req, err := http.NewRequest(http.MethodPost, u, bytes.NewReader(reqBody))
The `resource.ID` is obtained through the call to `/oauth/token/accessible-resources`, as instructed in the documentation.
I have a project set up with two cards, but the result set is empty:
❯ curl localhost:8080/search/jira -d '{"query": "Lasagna"}'
{"results":{"issues":[],"maxResults":50,"startAt":0,"total":0}}
Raw request:
{"expand":["names"],"jql":"text ~ Lasagna order by created DESC"}
But the same JQL returns results in advanced search in my account:
Figured it out: the call was missing the Access Token.
