I have a reference jira project called project A that has a masterlist of epics. Project B is a project with a few epics that overlap with project A (they have the same summaries but are distinct and unique epics, ie they have different issuekeys). I would like to execute a Jira query that checks all epics that exist in the reference project A that dont exist within project B. This JQL query should only compare the summaries of the epics for similarity. Is there any way to implement this functionality?
Hi @Talha Shah - You're not going to natively get that from JQL. However, assuming you don't have empty Epics, you could create a quick dashboard where you do something like this:
Filter
Project in (projectA,projectB)
Two-Dimensional Filter Gadget
All Epics will show in this view and any where ProjectB has 0 means that the Epic doesn't exist.
Your other option would be to simply execute a query like this:
project in (projectA,projectB) AND issueType = Epic
Then download the results to a spreadsheet and get the total there.
This is not possible (with JQL) as a native function out of the box. But you could use an add-on like ScriptRunner and execute an expression to search for the same.
