JQL nested parent function
Christian Scharrer July 3, 2023
I want to write a JQL query that delivers all tasks and their subtasks that are linked to an Epic. It is a team-managed project which brings some JQL restrictions.
the query
parent in (EPIC-1, ... , EPIC-N)
 delivers all task or user stories.
I hoped that a nested query like
parent in (parent in (EPIC-1, ... , EPIC-N))
delivers all sub-tasks of the corresponding stories, but it doesn't work. Any ideas how I could solve this?
4 votes
Charlotte Santos -Appfire-
July 3, 2023
Hi @Christian Scharrer
I’m Charlotte, a support engineer at Appfire and I’m here to help you.
Unfortunately, using JQL of Jira, you’ll not be able to do it dynamically.
In the app where my team works, JQL Search Extensions for Jira, you can use this query to display all stories and subtasks linked to an Epic:
issue in childrenOfIssuesInQueryRecursive(“issuekey in (EPIC-1, EPIC-2)”)
Please note that we have created a support ticket https://jqlsearchextensions.atlassian.net/servicedesk/customer/portal/2/SEARCH-1121 in our portal, and we request you to sign in to the portal and let us know the username so that we can mark you as the reporter, and then you will be able to access the ticket.
 Please find the below link to signup to the portal: https://jqlsearchextensions.atlassian.net/servicedesk/customer/portal/2
Looking forward to hearing from you!
Charlotte
Dan Tombs
Hey @Charlotte Santos -Appfire-
Just want to bring this one back up. Can the extensions app go higher then epic in terms of the recursive JQL.
If we inputted the following JQL for hierarchy below would it return all results issues below:
issue in childrenOfIssuesInQueryRecursive(“issuekey in (COPS-1)”)
  • COPS-1 (project)
    • COPS-2 (workstream)
      • COPS-5 (epic)
        • COPS-8 (story)
        • COPS-9 (story)
          • COPS-10 (sub-task)
      • COPS-6 (epic)
    • COPS-3 (workstream)
      • COPS-7 (epic)
    • COPS-4 (workstream)
Like Adam Sterrie likes this
July 10, 2023
Hi @Dan Tombs
Yes, it can go higher than epics. You would get all of those results.
Give it a try, you have 30 days to test the app for free: JQL Search Extensions for Jira
And if you need any help with the queries you can open a ticket for us in our portal
Charlotte
Like Dan Tombs likes this
Dan Tombs
Thanks for the note. I'll take a look and reach out to your support team if I have any questions.
Dan Tombs
Is there any way you can add me to that feature request for dynamic use of the extensions. Thinking of use within gadgets etc. Thanks.
July 12, 2023
Hey @Dan Tombs
You can use it in a more dynamic way, for example, if you use:
issue in childrenOfIssuesInQueryRecursive("project='ABC' and type=Initiative")
You would get all epics, stories and subtasks in initiatives in project ABC.
Is that what you mean?
Charlotte
Markus Fredén
July 3, 2023
Hi @Christian Scharrer ,
You can make use of the JQL function "sssueFunction";
parent in (EPIC-1, ..., EPIC-N) OR issueFunction in linkedIssuesOf("parent in (EPIC-1, ..., EPIC-N)")
/Markus
Trudy Claspill
@Christian Scharrer
There is not support for nesting filters like that in native JQL.
And note that "issueFunction in linkedIssuesOf" suggested by @Markus Fredén is not native Jira functionality.
That is available only if you have the appropriate third party app installed; i.e. Adaptavist Enhanced Search or Adaptavist ScriptRunner.
Like 5 people like this
Christian Scharrer July 28, 2023
This doesn't work in Jira cloud. This was the answer (but the link doesn't  work):
The "linkedIssuesOf" JQL function provided by "Adaptavist Scriptrunner" for Jira Server works differently in Jira Cloud. Run it directly in "Enhanced Search" instead. See the documentation for more details: https://docs.adaptavist.com/sr4jc/latest/features/scriptrunner-jql-keywords-functions
Register today
