I have the following query:
project = {MY_PROJECT} AND issuetype = Bug AND fixVersion = v1.0 ORDER BY Rank ASC
This return a huge chunk of data of all my bugs in the project. Now I want to filter the return data and have only the summary of those bugs.
Any ideas how to do so ?
Hi @Ilan Yaniv ,
If you are looking for configuring specific fields in the issue navigator, you can follow this article
Thanks for the response.
Can I remove the columns inside the query ?
Like select summary from .....
What do you mean by summary.. do you mean "summary" field? or you want to analyze the data further.. Do you have less than 1000 issues?
I mean the summary field.
I need the correct query that will return only selected fields such as:
- key
- summry
- status
I don't need all other information.
if you are using filters - advanced search - when you see the results, there is a "column" link right above the results - you can click and unclick the fields you want to see in the results field - be sure to click "done" after clicking and unclicking.
Yeah, that will work just fine.... but can I exclude those unwanted fields inside the query instead of clicking the "column" ?
not in the filter view (that I am aware of anyway)
