×I need help to automate releasing of a "release" but unable to fetch the issues that belong to a particular fix version using JQL in lookup issues option in Jira automation..
The objective is to trigger an automation to release a particular version once all the tasks part of that release are in status "Done/Deployed"
The fix version field is a list of values, and the rule needs to handle that accordingly. And to use the membership IN operator the list of values needs to be in parentheses. Finally, do any of your fix versions' names contain spaces or special characters? If so, the names need to be wrapped with quotation marks.
Perhaps something like this for your rule:
project = NC
AND issuetype = Task
AND fixVersion IN ( {{#issue.fixVersions}}"{{name}}"{{^last}}, {{/}}{{/}} )
To learn more about list handling syntax in rules, please review this documentation:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-lists/
If I understand the question correctly, then you need to enter the JQL in the following way
Project = XYZ and fixVersion="Your Version" and Status ="Done/Deployed"
Hope this helps!
Raja
Yes, and the fix version will be dynamic .
Tried using fixVersions IN {{issue.fixVersions}} but that does not give any result
earliestUnreleasedVersion() nextUnreleasedVersion() functions did not work for me either.
To generate the fix version in a dynamic way - please use like below
{{issue.fixVersions.name}} - Returns the name of the fix version.
This issue is part of the following releases:
* Fix version: {{name}}, released on {{releaseDate}}
// returns
• Fix version: Version 1.1, released on 2019-08-10T00:00:00.0+0000
• Fix version: Version 1.5, released on 2019-08-02T00:00:00.0+0000
To explain my objective better, attaching the screenshots. These are all the issues part of Release 1.18.100 that are in "deployed" state. Now I want to close the release 1.18.100
For this, i created the following rule, please have a look and let me know if it will work
{{issue.fixVersion}} or {{issue.FixVersions.name}} do not work in JQL
