JSM integration not creating tickets - Opsgenie
Chris Thomas
October 3, 2022
I created an email integration and it works fine. I then set up a JSM integration to create tickets in JSM but I keep getting errors in the log and no ticket being created.
Am I doing something wrong?
[outgoing][jira-service-management-cloud]Execution of action[createIssue] is finished with status[FAILED]. Execution message: [ ServiceName: jiraAdapter Response: { Status: 400 Body: [ {"message":"Field 'labels' cannot be set. It is not on the appropriate screen, or unknown.","took":0.348,"requestId":"XXXXXXXXXX"} ] } Request: { URI: http://og-jira-adapter-int-api.mesh:10609/api/jira/issues?customerId=XXXXXXXXXXXXX&identifierType=connection&identifierId=XXXXXXXXXXXXXXXXX&product=jira_cloud Body: [ {"customerId":"XXXXXXXXXXXXXXXXXX","identifierType":"connection","identifierId":"XXXXXXXXXXXXXXXXXXXXXXXXX","product":"jira_cloud","fields":{"summary":"Test 5","issuetype":{"id":"10375"},"components":[{"id":"10949"}],"project":{"id":"10015"},"description":"Click on [Body.html] attachment for HTML version\n\n\r\n\r\nMESSAGE ","reporter":{"id":"XXXXXXXXXXX"},"priority":{"id":"3"},"labels":["OpsgenieEvent"]},"sourceEntityId":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXX","sourceEntityType":"opsgenie-alert","targetEntityType":"jira-issue","relationType":"escalated-by"} ] }]
2 accepted
Chris Thomas
October 3, 2022
Figured it out. I needed to add labels to the create issue screen for that issue type. Thats because Opsgenie adds it's own label. However it's not setting the component even though I set it on the integration.
Jack Brickey
It looks like either you are trying to update the Labels field or possibly you have that field required when creating the issuetype. Is that possible?
Chris Thomas
October 3, 2022 edited
That's what it looks like to me as well but labels isn't even an option to customize. It's also not required on the issue type I am trying to create.
I should also note that I get the same message when only Summary is filled in.
