Java Script Load Error in Chrome
Rukhsar Qureshi June 10, 2022
Suddenly my chrome started showing the following error-
We tried to load scripts but something went wrong.
Please make sure that your network settings allow you to download scripts from the following domain:
https://aid-frontend.prod.atl-paas.net/atlassian-id/front-end/5.0.337
It was working properly earlier but suddenly it stopped working. It is working properly on Microsoft edge but not working on chrome. I also tried on chrome incognito but there also not working. I also enabled javascript for Jira URL from chrome setting.
My chrome version is - Version 102.0.5005.115 (Official Build) (64-bit)
Please provide me solution as soon as possible because I am unable to use my jira Account
natalia_daraszkiewicz September 26, 2022
We experience the same problem since 23/09/2022. Also Chrome.
John Funk
Have you removed all of the extensions?
Like • yuki moniwa likes this
natalia_daraszkiewicz October 14, 2022
It didn't help. The laptop (and browser) was managed by our vendor, so we couldn't disable all the plugins installed (e.g symantec). It got resolved by our vendor by enabling VPN for their employee.  They assumed it was related to ipv6, probably user's ISP made some changes.
Like • John Funk likes this
Dawson St. Julien
August 9, 2022
Im also having the same issue, but as of Monday 8/08/2022.
Ive disabled all my extensions, even deleted some. Deleted Chrome all together and reinstalled. I've turned off my computer, and made sure its up to date, with no luck. Safari and Firefox both work just fine.
MacOS: 12.5
Chrome version: Version 104.0.5112.79 (Official Build) (x86_64)
Dawson St. Julien
September 27, 2022
I purchased a new router and updated the information to my ISP and all is working again. Seemed to be a connection issue.
John Funk
Hi Rukhsar - Welcome to the Atlassian Community!
I would try removing all of the Extensions in Chrome and then try it.
