I am getting a Java stack trace when trying to import a CSV file. This used to work for the same file, so it would seem something has changed. I did recreate the projects to import into, but I don't see how that would impact things.
I had to cut off the stack trace as it exceeded the allowed post size. I have the complete stack available if that helps.
Exception rendering velocity file com.atlassian.jira.plugins.jim-plugin:actions/jim-module/templates/admin/views/csv/csvValueMappingsPage.vm
org.apache.velocity.exception.VelocityException: Invocation of method 'getIssueTypes' in class com.atlassian.jira.plugins.importer.imports.csv.web.CsvValueMappingsPage threw exception java.lang.NullPointerException at com.atlassian.jira.plugins.jim-plugin:actions/jim-module/templates/admin/views/csv/csvValueMappingsPage.vm[line 111, column 51] at com.atlassian.velocity.JiraVelocityManager.writeEncodedBodyImpl(JiraVelocityManager.java:87) at com.atlassian.velocity.JiraVelocityManager.writeEncodedBody(JiraVelocityManager.java:63) at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.toWriterImpl(DefaultVelocityTemplatingEngine.java:127) at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.asHtml(DefaultVelocityTemplatingEngine.java:118) at com.atlassian.jira.web.dispatcher.JiraVelocityViewDispatcher.dispatch(JiraVelocityViewDispatcher.java:49) at com.atlassian.jira.web.dispatcher.JiraWebworkViewDispatcher.dispatchViaVelocityView(JiraWebworkViewDispatcher.java:91) at com.atlassian.jira.web.dispatcher.JiraWebworkViewDispatcher.dispatchView(JiraWebworkViewDispatcher.java:58) at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:178) at javax.servlet.http.HttpServlet.service(HttpServlet.java:741) at com.atlassian.jira.servlet.WebExceptionCheckingServlet.delegate(WebExceptionCheckingServlet.java:91) at com.atlassian.jira.servlet.WebExceptionCheckingServlet.service(WebExceptionCheckingServlet.java:37) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.atlassian.jira.web.filters.JiraAbstractHttpFilter.lambda$doFilter$0(JiraAbstractHttpFilter.java:34) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:78) at com.atlassian.jira.web.filters.JiraAbstractHttpFilter.doFilter(JiraAbstractHttpFilter.java:39) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.google.inject.servlet.FilterChainInvocation.doFilter(FilterChainInvocation.java:89) at com.google.inject.servlet.ManagedFilterPipeline.dispatch(ManagedFilterPipeline.java:120) at com.google.inject.servlet.GuiceFilter.doFilter(GuiceFilter.java:135) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:21) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:37) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:40) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:67) at com.atlassian.servicedesk.internal.web.ExternalCustomerLockoutFilter.doFilter(ExternalCustomerLockoutFilter.java:56) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:75) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:38) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:67) at com.atlassian.servicedesk.internal.web.PortalLanguageDetectionFilter.doFilter(PortalLanguageDetectionFilter.java:120) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:75) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:38) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:67) at com.atlassian.greenhopper.jira.filters.ClassicBoardRouter.doFilter(ClassicBoardRouter.java:55) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:75) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:38) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:67) at com.atlassian.plugin.connect.plugin.auth.user.ConnectJavaScriptApiLoginFilter.doFilterImpl(ConnectJavaScriptApiLoginFilter.java:52) at com.atlassian.plugin.connect.plugin.auth.user.AbstractConnectAddonLoginFilter.doFilter(AbstractConnectAddonLoginFilter.java:68) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:75) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:38) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:67) at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:24) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:75) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:38) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:67) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:32) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:75) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:38) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:67) at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:55) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:75) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:38) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:67) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:79) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:75) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:38) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:67) at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:51) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:75) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:38) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:72) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:60) at
This was confirmed by Atlassian as a known bug.
The workaround seems to be to not select Issue Type for mapping.
Thanks @Sven Delmas , this worked for me.
I defined the issue type in the CSV file but did not select 'Map field value' for the issue type field.
The imported issues still ended up being created as the issue type I defined in the CSV.
