I have an automation that I want to look up issues where the due date is within the next 60 days.
Nothing gets sent. The audit logs state No Actions Performed.
If you try the JQL in the Lookup Issues standalone to test it with View All Issues, does it return any issues?
If so, in which project(s) are the issues? If the issues are in multiple projects and the rule is a single-project scope rule it cannot "see" the issues. The rule scope will need to be changed, and your Jira Site Admin will need to change the rule scope.
Bill,
Thanks for the feedback. It is for a single project. I rewrote the automation this morning from scratch, and now it appears to be working.
Thanks for the help.
Sometimes rules can get "glitched" due to many edit / publish cycles, breaking something behind the scenes in the JSON. Often the ways to check that align with what you tried:
@Brian Taylor is helped to solve your query still you are looking another solution
Pasam - The change in the query did not change the outcome. When I validate the query, I still get two issues with your query as I did with mine.
@Brian Taylor can you try with this Automation rule
Pasam, I rewrote the automation this morning, which is similar to what you had, and for some reason, it is working now.
Thanks for your help.
@Brian Taylor if it helps to you can you hit accept answers so that others can reach
