Jira Automation - Edit issue fields / User who triggered the event
Adrian Gierlach February 21, 2023
Hey,
I wanted to ask for advice regarding how I can use the same functionality that is built-in for the standard Jira fields like for example 'Assignee' when I can choose the option 'User who triggered the event'.
I want to use the same but for the custom field which in my case scenario would be QA Assignee - but there are limited options for it, only 'Copy from trigger issue' which seems not to work in this particular scenario.
What I would like to achieve?
When the issue is transitioned to a 'XXX' status - > change the QA Assignee to (User who triggered the event). Is there any other option to achieve it - maybe someone already did it with the Advanced mode?
11 votes
Ashish Bijlwan
February 21, 2023
Hi @Adrian Gierlach
You can add the below smart value to your Jira Automation. It will update the QA Assignee field to  the user who triggered the event.
{{initiator.accountID}}
Thank you,
Ashish
Thanks, Ashish,
It's working!
Like • Ashish Bijlwan likes this
Eduardo Pinheiro November 29, 2023
Thanks @Ashish Bijlwan,  I have the exactly some case, and this answer solves for me too.
Juliette Savey February 21, 2025
Thanks! It was perfect for me too!
Laura Russolo May 15, 2025
I Had the same issue and your solution works perfectly, thank you! s2
Upcoming Jira Events
