Jira Automation - Get created issue key
Shahroz Naeem
While using the Automation for Jira Cloud, is it possible to get the key of the issue that was created in the very same automation?
Here's a screenshot of what I'm trying to implement. The issue is created perfectly - I just want to send the Key of the created issue over Slack/Teams/Email without using JQL/Lookup to fetch it.
7 votes
Jira Guru
August 18, 2020
Hi @Shahroz Naeem
Try this
createdIssue
The previous issue created in this rule.
{{createdIssue.key}}
createdIssues
A list of issues that have been created in the rule.
{{#createdIssues}}{{key}}{{/}}
Shahroz Naeem
Thank you! 😁
Steven Peck
March 16, 2022
Is there a way to access created Service Requests?
Shahroz Naeem
Hey @steven_peck
I'd suggest you start a new thread for this query.
But to answer your question: Yes, all created tickets can be accessed. You can use the conditions to filter out the tickets where the issuetype is Service Request and take actions on them alone.
Like Dave Liao likes this
Dave Liao
January 5, 2023
...for anyone who's reading this thread 3 years later, @Jira Guru 's useful answer is from this page, where there's lots of other smart value info: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/
Like Katherine H likes this
3 votes
Łukasz Zawer
July 8, 2021 edited
I'm sad that is hard to find again this version of getting (spent 1-2 hours to get this).
If you create more than one in single automation - you can use (even if created in Branch-rule):
{{createdissues.get(0).key}} - for first
{{createdissues.get(1).key}} - for second
etc.
