Jira Automation Smart Value to email/slack all sub Issues in a List/Epic/Version
Kenny Dickie April 20, 2020
Using Jira Automation, I'm looking for a way to send an email/slack of all the issues in a Project Version.
I can get the version details using the version. smart tag.
I can then branch to find all Issues in that fixed in version.
I can create an email that has the version information but I'm not sure how I can include information for each issue that's in that version.
Is there perhaps a way to store a global variable that I can append smart tags to in the branch issue loop and reference that in the email step at the last step?
June 26, 2020
Hi @Kenny Dickie
Sounds like you have all the pieces and just need to knit them together.  How about this:
  • Trigger on version released
  • Action to lookup the issues with JQL for the FixVersion
  • Use list iteration to create a table of the values using HTML in the email.  Maybe something like:
Here is the list:
<ul>
{{#lookupIssues}}
<li><a href="{{url}}">{{key}}</a></li>{{/}}
</ul>
Here is the documentation on smart value lists if you need more information:
https://support.atlassian.com/jira-software-cloud/docs/smart-values-lists/
Best regards,
