Jira Automation Web Request through Application Tunnel?
Pieter Wouter Hartog
November 22, 2023
I setup an Application Tunnel between Jira Cloud and our locally hosted Bamboo Data Center.
How can I post a web request from Jira Automation to my local Bamboo DC through the Application Tunnel? For example, I want to queue a build in Bamboo using the Bamboo REST API.
When I check the URL in the Application Tunnel, it accesses Bamboo with a URL similar to this:
http://ee6<many numbers and letters>bab592.self-hosted.atlassian.com
But when I post a web request to that URL, it basically times out.
How can I reach my local Bamboo through Application Tunnel with Jira Automation?
Trudy Claspill
Hello @Pieter Wouter Hartog
I don't think that you can use the Application Tunnel for that purpose.
On a response in this post asking if the Application Tunnel can be used for web requests, an Atlassian Team member has responded that you need to open a port on your internal system to allow the HTTPS request to come in from the internet. That implies that the Application Tunnel cannot be used.
November 23, 2023
Thanks for finding that other post.
I can't find any other info on this either, so I assume it's not possible for now.
It seems that Forge or Connect apps can't use the Application Tunnel either, per these two feature requests:
https://ecosystem.atlassian.net/browse/FRGE-817
https://ecosystem.atlassian.net/browse/AC-2541
So even though there is this great Tunnel solution, we can't use it besides some limited uses in the standard Jira system....
Like • Steffen Opel _Utoolity_ likes this
Emanuele Mariani February 16, 2024
it not works, please vote:
https://jira.atlassian.com/browse/AUTO-1122 .
November 23, 2023
Read the story
