Jira Automation by Project Category
Ken
October 25, 2023
Hello Brains Trust
Automations, I have an automation I need to limit to only work by specific project category types... how (can) I do this?
 I know I limit to:
  • Global - not the best as there are some projects that don't have a field I need to update, leads to errors and is not a very elegant solution (but an ok workaround as the errors don't effect anything apart from the audit log)
  • Single project - I need to run it across a number of projects
  • Multiple projects - I want it to be dynamic, i.e. so users don't need to remember to add it to the automation if they create a new project.
  • Project type - I need it to potentially run across project types
TIA
3 votes
Mikael Sandberg
You cannot limit the automation under rules details to a specific category, but you can add a JQL condition in your rule that checks if the issue belongs to a project in a specific category like this:
October 25, 2023
Hi @Ken
Adding to Mikael's answer...
I think the smart value to check for the project category is:
{{project.projectCategory.name}}
or the id value if you want to use the numeric value.
Like # people like this
Heidi Hendry
