Sign up Log in
[Jira Automation] - clone issue as sub-task to another specific issue
Danielle Bonneau
hello!
I am attempting to do the following:
When a specific label is added to a ticket, clone that ticket as a sub-task to a SPECIFIC ticket in the Backlog (that isn't the Trigger or Current issue).
What I can't figure out is how to specify the parent ticket.  I only see the option of setting the parent as the Current or Trigger issue, and if I try to add branching for the specific ticket I'm looking for, it clones the specified ticket, not the original trigger one.
I've tried these actions, all of which only seem to allow you to select the Current or Trigger issue as the parent:
Clone issue
- create sub-tasks
- Create issue
- Link Issue (tried to link it to the ticket i want then clone to link, but again, only can link Trigger or Current issue)
Thank you for your help!
-Danielle
September 8, 2021
Hi @Danielle Bonneau
I recall seeing this question in a similar post a while ago, and there wasn't a resolution using one rule.  To save you some time, it appears that you also cannot change the parent of a sub-task using JSON.
A convoluted work-around would be to use two rules and a custom field.  For example:
Rule 1: triggered on your case of the label being added, and then add *that trigger issue's key* to a custom field in the future parent ticket (e.g. named IssueToClone)
  • trigger: label field changed
  • condition: label changed to your specific value
  • branch: on JQL to the specific new sub-task parent  (It is unclear how you planned to do this...)
    • action: edit issue to set the custom field (IssueToClone) to the trigger issue's key
Rule 2: triggered on a value change for the custom field.  In rule details, enable the "Allow Rule Trigger" option to allow Rule 1 to trigger Rule 2.
  • trigger: field changed for IssueToClone
  • condition: IssueToClone is not empty
  • branch: on JQL for key = {{issue.IssueToClone}}
    • action: clone the issue, changing issue type to sub-task and changing the parent to Trigger Issue
Marlene Kegel - codefortynine
Another option would be our Jira cloud app Deep Clone for Jira.
Our app can be integrated with Jira Automation using looping transitions. The clone gets triggered by a post-function, but since the transition is looping the status won't change.
Setting up the Deep Clone post-function and define the parent issue is very easy, as you can see in the attached screenshot.
If you have questions or feedback, don't hesitate to contact us.
