I try to create an automation based on a manual trigger. I want to create some "validation" process for a document, but I can't use the workflow for that.
Basically, the automation gather some informations (the user which will validate the version X of the document ; the version number (1, 2 or final) ; the date when the validation is expected). Then the automation add a lable to the issue (Validation_Pending). Then an email is send to the user who should validate with the informations in the body.
In a perfect scenario, I would like the automation process to be able to check that "if the issue still have the "Validation_Pending" label, then send an email reminder (with the same info) at date-2day, date-1day and at the date provided in the initial prompt.
So what I've tried : I've set up this manual trigger with a prompt for thoses user's input, like :
Then I have an action to add the label "Validation_Pending" to the issue. No problem here.
Lastly I set an "Send email" action.
The To field use the {{userInputs.automationValidatorEmail}} variable.
Other variables are used in the body of the email.
Question 4 : the issue has a weblink to the document version (stored outside of JIRA). Is there a way to get this link for the issue and pass it to the email body ? Sometimes we have multiple links attached to an issue, so a prompt asking the personn who trigger the automation, asking him to select a link between the multiple should be perfect. Is that possible ?
At this point of my experiment, I can't figure how to set other automation (in another branch of the same automation, or in another automation) to watch the ticket, check if the label is still here, and if so, send email reminder based on the date provided in the first prompt.
Thanks for your help. (sorry for my english, and best regards from France).
Regarding your questions...
Question 2 : I don't find any way to get a single user picker to gather this info, and then retrieved the email adress for the "send email" action).
There is no user picker yet for the user inputs for the manual trigger. Here is a suggestion to add sources/ways to populate those questions: https://jira.atlassian.com/browse/AUTO-744
Question 3 : is there a way to get a date picker ?
Same answer as for question 2: this is not possible yet.
Depending on where that information is stored, perhaps you could use a web request to call a REST API function (to some external system) to get the data. Please look here to learn about that technique: https://community.atlassian.com/t5/Jira-articles/Automation-for-Jira-Send-web-request-using-Jira-REST-API/ba-p/1443828
Regarding selecting from the links already attached to the issue, this would be the same answer as for question 2.
For this last idea, you could use a scheduled trigger to periodically check that label for your value and then take action.
Hi @Bill Sheboy
Thanks for your answers, and the link provided. I will watch the progress.
For the last answer, regarding the sheduled trigger, I guess that, as the date is only provided inside the first automation input prompt, I can't base my second automation on it, right ?
Maybe if I fisrt put this date inside a default or custom field of the issue, then I could recall it ?
But how to use some value like dd/MM/YYY, put by the user in a simple text field (inside the prompt) and copy it in a real date field (like the dafault due date) ?
I will try to answer the different questions you asked there...Please let me know if I miss any of them :^)
A scheduled trigger rule runs on its schedule. It cannot have a dynamic schedule based on issue data. This trigger can use JQL to gather issues on that schedule, helping to manage executions. (For example, create a rule that runs once per day and which only proceeds if there are open issues that have not been updated in the last day.)
You also asked about having the users of a manually triggered rule enter a date value, and then store that in a date field. That is definitely possible using the date conversion functions. And, as often is the case for text fields, the challenge is: will the user enter the date in a valid format? If they do, the value can be converted and captured.
Thanks a lot @Bill Sheboy to take time to answer me.
I will think again of my workflow with all those rules in mind.
Best regards, Eric.
