Jira Cloud Automation: display subtasks fields in the parent issue
Abdeladim EL AOUMARI April 7, 2021
hello,
I have sub-task1, sub-task2, sub-task3 created under a parent task.
I want to extract the value of a custom field present in all subtasks and display them in the parent issue.
  • Question 1: is it possible using Jira automation to get the value of this field from all the subtaks when ever a subtask is created or updated, and display them in the parent task ?
  • Question 2: using jira automation is it possible to diplay these values in a table (multiline text field & [Wiki Style Renderer]...) ? and eventually update this table whenever the value is updated in a subtask ?
Abdeladim,
Carlos Faddul
April 7, 2021
Hello @Abdeladim EL AOUMARI
About the questions
In this case using branch you can get this informations.
You will need use variables in automation to store the past information
Abdeladim EL AOUMARI April 8, 2021
Hello @Carlos Faddul
Thanks for your answer :)
let say I created a specific sub-task type.
My automation trigger is whenever that sub-task type is created (or updated) then I branch "for parent" so I can put the value of a specific field in the parent task. see the screen shot. With this automation rule I can't get the value of that field from the other sub-tasks and dislay them all in the parent issue.
I dont see how I can branch so I can update the parent and then branch to get all sub-tasks of that parent issue. if it possible to do, can you send an example ?
I need this automation rule to be used for an issue type. I dont see how I can in one automation rule use variables to store the past information of all issues sharing the same issue type. can you send an example ?
Carlos Faddul
April 13, 2021
In this case you can use two branchs to do this.
- One branch to run in your sub-tasks using a variable to "sum" the values.
- One branch to change the parent issue
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
