Jira Cloud: How to make a custom field mandatory based on value of another custom field
Xheneta G. Hyseni June 9, 2022
I have a cascading field which has two options (let's say Option A and Option B). For Option A, I have two other sub-options (Opt1 and Opt2) but for the Option B I have only one sub-option (Opt2).
I need to make the custom field called "EndDate" mandatory if Option B is selected.
Since there are no Behaviours in Jira Cloud, I am not really finding any solution for this.
Do you have any suggestions?
Jack Brickey
June 9, 2022
Hi @Xheneta G. Hyseni , indeed you would need something like Scriptrunner behaviors to achieve this in cloud. There is not an OOTB solution.
What a pity! I guess, I have to split the cascading fields into two fields and see what I can do via the workflow. -__-
Like John Funk likes this
khalid June 21, 2023
hi,
if your project type is "service"
then this will help you
go to your project-project setting and choose dynamic forms
then you can choose for example the cascading field and the mandatory field "required"
