Jira Cloud - Slack integration
Angel Todorov September 29, 2020
Hello guys,
We did Jira Cloud - Slack integration when Jira has a certain number of projects. Later, I decided to add one more project in Jira. However, I cannot see the notification from that project in the Slack Jira App channel. My guess is - the Slack integration for this project is not done. How can I do that? I found this guide - https://confluence.atlassian.com/slack/using-jira-applications-with-slack-966662163.html however it shows older screens, and I cannot figure out where to find and configure Slack notifications in Jira Admin for the new project.
And yes - I have Jira Admin rights.
Patricia Francezi
September 30, 2020
Hi @Angel Todorov
Check if the snapshots are helpful
If Classic projects i will find in the navigation bar
2020-09-30 05_56_05-Caixa de Entrada - patricia.francezidelima.ext@centurylink.com - Outlook.png
If Next-Gen you will find in Project / Settings / Apps
