Jira Cloud Software and Advanced Roadmaps
AlbionPM
March 2, 2021
Greetings
     I am new to Jira Software (Cloud) Premium application.   I seems to can not find how to set or access advanced roadmaps.   I did reviewed the documentation but it is just not working.   What am I missing?
Jack Brickey
if you indeed have Premium then you will see "Plans" in the top menu bar. If you do not see then you may actually be on Standard.
AlbionPM
March 2, 2021
Greetings Jack
    So I have to create a plan first to access advanced roadmaps?
Jack Brickey
well this is where I fall off the expert train as I do not have premium and don't use advance roadmaps. With that said....yes it is my understanding that you create a plan which is your roadmap. I defer to the docs on this.
Dave
March 2, 2021
Hi @AlbionPM ,
I guess the confusion here is that an "Advanced Roadmap" is essentially a plan... when you create a plan you will see 4 tabs ("Roadmap", "Teams", "Releases" and "Dependencies Report") and it's the "Roadmap" tab that you do the planning work in.
Advanced Roadmaps also provides a Teams field and the ability to create additional hierarchy levels above Epic - but you don't need to create a plan to access these features.
I hope this helps,
Dave
Help us plant more trees
