×Is there a config setting to have Jira issues pop out instead of the issue showing on the side of the screen when you click on the issue. The team rather that once you click on the issue a pop out displays the details. Thanks.
Thanks John. That worked. I appreciate the help!!
Great! I am glad that worked for you.
Not sure why the view in the Backlog is different. Here is a link to the work being done on the New Issue View.
https://jira.atlassian.com/browse/JRACLOUD-70555
If you don't find an open item for that, you might want to make the suggestion. :-)
Hi @larias ,
If you switch over to the New Jira Issue View, it should pop up when you click on a card on a board.
To change, click on your avatar in the top right corner of the screen.
Then select Personal Settings.
Then about halfway down toggle on the New Jira Issue View.
Then hit your browser back button.
