Jira: How can I add custom labels on issue board?
Ahmad Pouei June 20, 2020
I need to add/remove some labels on issue board. Is there anyone to know this?
Aron Gombas _Midori_
To me it sounds that what you want to change is the name of the columns in the top. (Note that the term "label" has a completely different meaning in Jira.)
For that, go to the board configuration and you can rename the column as you wish.
For classic boards, see: https://support.atlassian.com/jira-software-cloud/docs/configure-columns/
For next-gen boards, it is quite similar.
Vero Rivas
June 20, 2020
Hi Ahmad,
To add, first make sure that in the incidents configuration, you have the "Label" field visible, you may have it configured so that it is hidden when it is empty.
Once this is done, to create a label, just type in the field the name you want and then to remove them from the issue, just click on the "X" and it will disappear from the issue immediately.
Tell me if my solution helps you.
Regards.
What do you mean this "incidents config"?! I have Kanban board, and I should change labels like in progress, done, ..
Vero Rivas
June 20, 2020
Well to remove the labels, deleting them is enough and to add them you just have to create and move them on the board
I think I did not understand you correctly, sorry
FREE
Register now
