I created a Jira Scrum Board and set up automation for subtasks. I am manually triggering the automation as stories are created. At Story 6 I could no longer trigger the subtasks. I don't know why the automation stopped.
hi Laurie,
Could you please check the audit log of your automation rule ?
you can find the audit log just above the rule trigger
Also,
Is the rule set on a single or on multiple projects ?
free plans are limited on multiple projects automation rule execution...
Hi @[deleted]
Yes, and...to what @Mathieu Truchot suggests:
For a question like this please post images of your complete automation rule and audit log showing the execution details. That will provide context for the community offer suggestions. Thanks!
