Jira Software
Hello @GD_Google_Developer,
Allow me to step in to check if you found the answers to your questions.
Since you marked Dave's answer as accepted, it would be great if you could share with us what was the solution, so it would help other community members that have the same questions.
I see that you are a site administrator of many Cloud sites, so we want to make sure you have the help you need and that everything is clarified.
Angélica
Actually, the Atlantic community is wonderful, even if there is not enough response, a spirit of cooperation and interest in every sense of the word
sincerely
GD Google Developer
@GD_Google_Developer we try our best! We're a small cadre of devoted champions!
@GD_Google_Developer - your first question alone is an interesting one. Can you rephrase what "analyzing icons" means? 🤔
Yes, I can do that through a series of complex procedures, unfortunately, but they are technically and technically practical in this regard. This is why I am trying to direct advanced to enhance data protection and isolate threats according to my own programmatic command chain that creates a closed space for controlling the communication system. Malware within advanced access techniques
@GD_Google_Developer - can you rephrase that? It looks like you're using word pasta (unintentionally or otherwise). If English is not your native language, feel free to post in your native tongue and I'll attempt to translate. 😉
Well, to be precise and clear in the answer, create a space for any application and the name of the space is identical to the name of the application. It is not managed access, this work is difficult but it can be performed although I honestly work from a mobile phone but I upgrade the performance of the simulation etc.
Would you like to create Confluence instances for your app?
What's your experience with Atlassian apps?
Your responses are fascinating.
