Noticed the Jira Admin , settings , API screen change addtional of Organisation ID ?
Has something changed ?
Example
https://api.tempo.io/core/3/worklogs/project/AAA?offset=0&limit=1000&from=2020-01-01&to=2020-12-10
See the example i provided , when excuted through the WeB Browser data was returned successfully up and till the weekend . I now get an 401 Authentication Error . I have been using Bearer authentication in the headerr record. So when i checked to see what had changed on Jira , i noticed that there is now an addiotnal fileld that has been added in the Tempo setting API screen called: OraginsationID , not sure if there is now new rules that need to be applied
Found the problem had to re-add a new token in tempo API intergation screen .
Help us plant more trees
