We are currently assisting non-dev teams with setting up Jira Work Management projects using the provided templates.
To assist with administration, we lean towards company-managed projects.
At the moment, we've noticed there isn't a clear way to know whether a project template (for Jira Work Management projects) is team-managed or company-managed.
We've had a looked at previous posts and online documentation but have had no luck.
Is there a list of which Jira Work Management project templates are team-managed and which ones are company-managed?
Thank you 🙂
Hi Venecia
The templates will apply to both types. However, as you go to the step to put in a name and key for the project, there will be a link for more options. You should click on that.
There you will be able to select Company-managed or Team-managed. It defaults to Team-managed if you don’t do that step so be sure you do that before actually creating the project.
Lifesaver! My eyes were def failing me - thanks so much @John Funk 🙏.
I've just expanded that section and can now see the Project Type options:
