Jira automation : Creating a linked issue with subtasks
Jean Francois Gelinas
Greetings !
Here's my problem.  When an issue is created by user, I want an automation to run and create 2 new issues with subtaks in those new issues.  Something like :
Issue A is created by user ....
Issue B is created by automation
  • Subtask B.1
  • Subtask B.2
Issue C is created by automation
  • Subtask C.1
  • Subtask C.2
I have no problem creating B and C and linking A, but I'm not able to populate the subtasks under B and C.  Should I use advanced fields in JSON ?  Is it even possible ?
Thanks for your time
4 accepted
4 votes
Jorge Martinez
May 6, 2022
Hi @Jean Francois Gelinas this could work for you.
Trigger - Issue Creation
Step 1 - Create new issue (B)
Step 2 - Create new issue (C)
Step 3 - Create a branch for all new issues
Step 4 - Create two subtask per new issue founded
Rule
Details
Hint: Use smart values to customize your new tasks
Results
3 votes
Ulrika Eriksson
Create branches in JIRA  automation by using smart values.
Alberto Salvante
May 6, 2022
Hi Jean!
I think you should use branch to archive your purpose.
Here is an example:
Hope it helps.
Best,
Alberto
Craig Nodwell
Agreed with @Ulrika Eriksson create branches in Jira automation by using smart values.
Jira Automation - Branches
Jira Smart Values
CJ Edwards
One potential solution is to have a second automation that is triggered by Issue Creation
IF Link Type "zxy"
Then create that creates the Subtasks for each new Issue created by Automation #1
Issue B is created by automation rule #1
Issue C is created by automation rule #1
rule #2 is triggered by the other issues being created
Subtask B.1 created by automation rule #2
Subtask B.2 created by automation rule #2
Subtask C.1 created by automation rule #2
Subtask C.2 created by automation rule #2
Read the story
