I have created an automation rule that creates a branch when a Jira task has been moved to in progress.
In the event that the task is moved back to the assignees TODO to fix a change and the assignee moves it back to their In Progress column again how to prevent the rule from trying to create the same branch again?
There are several ways to do this, depending upon your rule structure.
The first approach may be easy to try, and to make adjustments as needed.
Ok, thanks. I will give these options a look and see what I can achieve.
