Jira automation to Copy All release notes from all linked tickets in the parent ticket
Dirk De Mal
Hi there,
I'm looking for a Jira automation where the release note fields from all linked tickets are all added to the release note field of the parent tick. To get some kind of automated overview in the parent ticket.
Tried it using branching in the automation but have not been succesfull.
Many thanks for all the help.
Dirk
Mark Segall
Hi @Dirk De Mal - How are you determining "parent ticket"?  Is this a situation where all of the issues roll up to an epic or are you using a custom link type to establish a logical hierarchy?
This will help in determining the best path for consolidating the release notes into one issue.
Dirk Ronsmans
February 7, 2023 edited
Hey @Mark Segall ,
The parent issue here is the "trigger issue". So for example let's say the moment that issue is transitioned to a specific state.
There will be several linked issues on this trigger issue (no matter the link type). The goal is to capture a custom field from the linked issues, concatenate the values and edit the trigger issue with this value.
So it'll be a custom link type (not the epic link).
The main issue seems to be that in an Automation, the second you branch the data from within the brand itself it not accessible outside of the branch/root automation rule.
(Seems to be this: https://jira.atlassian.com/browse/JSWCLOUD-22527)
Mark Segall
This should be able to work...
  • TRIGGER: Field Value Changed (Release Notes)
  • CONDITION: Issue Type not equal Epic
  • BRANCH: (Parent)
    • ACTION: Lookup Issues
      • "Epic Link" = {{issue}}
    • ACTION: Edit Issue (Release Notes)
      • {{lookupIssues.Release Notes}}
Dirk De Mal
Hi Mark,
Big thx for your feedback.
The parent ticket is not an epic ticket but a created issuetype (Release). My mistake.
So this is the automation we are working on...Everything works as expected until the last action...
  • TRIGGER: Manually triggered (for now)
  • CONDITION: Issue type equals Release
  • CONDITION: Linked issues present (All link types)
  • BRANCH: For linked issues (all link types)
    • ACTION: Create variable (Getreleasenotes)
      • Smart Value : {{issue.fields.ReleaseNote}}
    • ACTION: Add value to audit log
      • {{getreleasenotes}} (to check if the value is correct and it is)
So the next action is where I am stuck...Would it be possible to write the {{getreleasenotes}} value to the triggerissue value using the additional field configuration?
Many thx again for the help.
Dirk
Mark Segall
I would try this:
  • TRIGGER: Manual
  • CONDITION: issueType = Release
    • issueLink = {{issue}}
Note - If you want some formatting and your release notes field is set to use wiki renderer you could do something like this:
{{#lookupIssues}}
- *{{key}}*: {{Release Notes}}
Dirk De Mal
Hi Mark,
Tested it and it works...
Big big thx for all the help.
Dirk
Like • Mark Segall likes this
Dirk De Mal
Hi @Mark Segall ,
Thx for the help. The parent ticket is an Epic ticket where all of the issues reside under. We just link the tickets under an epic ticket.
Many thx for your help on this.
Dirk
