Automation Rule will be Trigger > Condition > Action. See Bellow
Accept the Answer if it helps
In the rule image you posted, the Send Email action is outside of the branch...and so the email will always send regardless of the count. To make it conditional, move the Send Email action inside the branch and after the Condition test.
Hi Bill,
Would it work better that way?
I've tried it and didn't receive an email.
Thank you for your help,
Mathilde
Hi, Mathilde.
Your image does not match what I was describing. What I meant was based upon your initial rule image with the branch. Please note that I suggested moving the send email action into the branch nesting.
Of note:
And if that still doesn't work please let me know, as there may be another possibility: a calculated field from an addon.
Sorry for my late reply.
I've tried several ways, but this automation doesn't seem to work. I do not plan to have more steps in the rule.
I want to receive an email anytime an issue on Jira has the field, Zendesk count greater than 50.
Do you think it's possible ?
Let's try creating a new very simple rule to learn what is happening.
Then find an issue you expect to have a count and run the rule from the issue (under the lightning bolt icon). When you check the log, what value is shown?
If nothing is shown, it is possible that is not the correct name for the field's smart value. You can confirm the smart value by following the steps in this how-to article: https://support.atlassian.com/cloud-automation/docs/find-the-smart-value-for-a-field/
Is the value of the Zendesk Count field equal to or greater than 50 for JBR-104?
