I am Jira and Confluence admin for the company. Jira users are allowed to create projects. But they cannot add people to the project. From Project settings, they see the Access item and can navigate into the gui for adding people. The button to add people is active. But they are unable to display the relevant user names to be added. I as "super-admin" have to do it for them, at the moment. As Project Admins (it is their own projects, and they show up as a person with the "Administrator" role in the Project settings/Access pane) they should be able to add users without my help. How can this be accomplished?
Thanks in advance!
br
Johannes
So they start typing a name but it does not show up? This should not be the case. Is it happening with multiple projects and users?
Thanks for picking up my issue: yes, exactly. and it happens for multiple projects and users.
When I type the (start of) names I get a list of matching users to choose from. The others don't get this.
Hi @Johannes Melkeraaen , can you check if your Global permission allows users to have Browse users and groups permission.
click on the gear icon in upper right then system > global permissions
Thanks for the tip, Jack! I have now added this permission to the "All users from Azure AD" group. I will comment again once I know if this does the trick, most likely by Monday.
br
Johannes
