In kanban board list (project type = Classic), my custom icon PNG for bugs doesn't display. I get the little red box with the white dot inside.
In bug details from that kanban board, I do see the custom bug icon.
Any way to fix this in the kanban board?
Here's the detail view showing custom bug icon in corner:
And here's the board view showing the default bug icon. :(
Hi @Eiren Smith
I am able to replicate the issue at my end.
As a workaround, go to Board settings > Card layout page and add any field to the layout.
Then go back to board and see that the icon updated with the new one.
You may again go to Board settings > Card layout page and remove the field you added earlier.
Thanks. Too late for me to try this because it is now fixed. Perhaps I performed the steps you describe, or perhaps it just took a while for the custom icon to propagate. I do not know. Today is Monday and I was having this icon problem on Saturday.
Glad to know that it's fixed now for you, @Eiren Smith . You are right, it may be taking a long time to propagate on to the card layout.
Save your spot
