We had a bunch of issues with a label.
By mistake, using the bulk editing the label has been deleted from around 60 issues and we want to add it again / check which issues had that label.
Many thanks
Unfortunately, the labels field does not support history search. If you know when the accidental update occurred, you can narrow down through a search on updated issues in that time frame:
updated >= date1 and updated <= date 2 and labels is empty
On the history tab of each issue you will be able to retrieve the update. Locate this at the bottom of your issue screen under Activity > History. An updated label will show somewhat like this:
The better you have an idea of when the bulk update was initiated and what the initial filter was that triggered it, the easier it will be to find the impacted issues.
Read the story
