Limit for creating issues
Silvio August 14, 2023
Hello, is it possible to limit the user to create certain issue-types?
For example, it cannot create an epic, but it can create task and subtask issues.
2 accepted
Tuncay Senturk
Hi @Silvio
Jira Cloud does not have a built-in feature to restrict users from creating specific issue types. However, if you have Script Runner or JMWE on your instance, you can do this by building your own validator.
Tuncay Senturk
You can find a similar thread discussed here.
Sanjog Sigdel
Hi @Silvio
By default there is one permission scheme to define whom we can provide access to create/edit/delete issues and other jira properties.Screenshot from 2023-08-14 17-25-32.png
however @Ste Wright  shares this workaround using validation in workflow issue transition here:-
https://community.atlassian.com/t5/Jira-Software-questions/Restricting-creation-of-certain-issue-type-based-on-project-role/qaq-p/1464615
Try this out. This might help you.
