×Hello Team,
i need a solution for linking multiple jiras to a single one .
Currenlty i have 50 bugs which are to be linked to parent task so is there any shortcut for doing so .
Hello @Saajan Kumar Sahu
Welcome to the community.
Is it possible for you to construct a filter that will bring up just the 50 bugs that you want to link to the parent task? If so, then you could create a manually triggered Automation Rule to retrieve those 50 bugs and link them to the parent task.
One way or another then you will need to type in the issue key for each bug.
You can add multiple linked issues in the Linked Issue section of an issue by typing in each issue key and selecting the match from the list. You can add multiple issues in the field and then save them all at once.
Currrently this is the method i am using.
earlier if you paste maultiple JIRA IDs comma seperated then is used to link but now i dont find the option.
So i was just looking for any shortcut to do so .
Hi Saajan, check that article
