List of components in the issued with the same fix version
Sona Evanesyan
August 13, 2020 edited
Hi ,
We want to start using components. Have multiple projects in a board and give the same fix version to the subject release all projects' issues. Now I need to get list of components that are mentioned in the tasks with fixversion = X . Would really appreciate you help!
Coley Anderson
August 13, 2020
Hi there,
you can do a JQL like this
fixVersion = "whatever you named it" AND component is not EMPTY
to see all tickets using components
Sona Evanesyan
August 14, 2020 edited
Thanks for the answer , unfortunately that is not what we need .We do use JQL for =having tickets with components but I just need lists of components ( not showing duplicaion ) used in projects with fixVersion = " whatever at that moment "
Thanks anyway !
Coley Anderson
If you are using the same fixVersion across all projects, and you want to see a list of components actively in use you can do a two dimensional filter in a dashboard.  I am still not sure if this is what you are asking for, but it would look similar to this.
  • Create the filter -fixVersion = "whatever you named it" AND component is not EMPTY
  • Create a Dashboard and add the 'Two Dimensional Filter Statistics'
  • Use saved filter, XAxis - Project, YAxis - Components
  • Number of results - the max is 50 to display
 It would look like this, give you a list of components and the number of times used in each project. If you click the numbers, it will take you to a list of the tickets.
Like • Erik Muijs likes this
Sona Evanesyan
Thanks a lot , will try and write here whether I got what was in my mind !
Like • Coley Anderson likes this
Sona Evanesyan
Hi @Coley Anderson ,
It worked , Thanks a lot .
Maybe you can also help me to insert it in a confluence doc like queries with filer , and any option of geting the same info in an editable table.
Thanks in advance
SE
Learn more
