Lock or save a filter
Tim Riches November 1, 2022
Hi everyone,
I use labels for projects.  I'd like to save a filter on a Jira board - like the one in the picture below where I have a filter with a label.
As things stand this filter is lost when I move from 'Board to 'Timeline' which is really frustrating and means a lot of clicking to reset the filter each time.
Is there a way to lock the filter or save it somehow?
Tim
Brant Schroeder
@Tim Riches Since you are using a Work Managed Project there is no way to create a saved filter on the board.   The board does create the filter using URL parameters.  As a workaround you could create a bookmark and then click it to return to the board with your filters on it.
You can also create a saved filter to see issues (this would not be on a board).
Another option would be to use a software project and a Kanban or Sprint board which allows you to create quick filters.
Tim Riches November 2, 2022
Thanks @Brant Schroeder Brian,
Bookmarketing the filtered views is a useful workaround. I'll look into quick filters as well.  Thanks for the tips.
Tim
Like Brant Schroeder likes this
FREE
