Cloud version -
Using four primary issue types. Epics, Stories, Task, Sub-Task.
Would really like the ability to allow work to be logged (via Tempo) so that time can only be charged to Stories and Tasks.
I've seen some articles surrounding adding the .denied permission on the Workflow, but was curious if anyone else would have a fix for this.
Thanks much in advance.
Are you looking to limit log work entirely for Epic and Sub-task - or only via Tempo?
Given this is a Tempo question, it might also be worthwhile getting their direct help - you can contact the vendor via their support page in Marketplace:
Ste
@Ste Wright Thank you, Stephen. I'm looking to log work only for Epic and Task, nothing else. I'll take a look as you suggested.
I'd contact Tempo first and see if it can be restricted there.
If not, there might be something you can do in Jira - although it might be a workaround. For example, use Automation in this manner...
Let us know if you find a solution with Tempo!
Ste
