Looping of automation
Ivan Andrieiev
I need to create one task every month, I created an automation, but the rule looped and created 105 tasks in 2 minutes, what's the problem?
December 13, 2023
Hi @Ivan Andrieiev
Please check the scheduled trigger's frequency for your rule.  It is likely set differently than you planned.
If that does not help, please post an image of your complete automation rule, images of any relevant actions / conditions / branches, an image of the audit log details showing the rule execution, and explain what is not working as expected.  Those will provide context for the community to offer ideas.  Thanks!
Ivan Andrieiev
@Bill Sheboy  Hi,  forgot about screenshots Ð—німок екрана 2023-12-13 о 15.59.28.png Знімок екрана 2023-12-13 о 15.59.44.png
Like • Dzung Ho likes this
Walter Buggenhout
Hi @Ivan Andrieiev ,
In your last screenshot, you have added a JQL with a very broad scope:
issuetype = task
This filter will retrieve every single task in your project and create a task whenever it finds a task. If you just want to create a single task, you have already specified that in your automation rule. So just uncheck the box next to Run a JQL search and execute actions for each issue in the query, or you will be getting a lot more tasks created on January 2nd.
Like • Bill Sheboy likes this
Ivan Andrieiev
@Walter Buggenhout  @Bill Sheboy
It works. Thanks.
