Hello
I created an automation rule to create two sub tasks upon creating a story, and it is working normally.
Now I want to manually trigger this rule for the previously created stories, but I can't find it in the issue's view.
In fact, in issue's view, I go to Automation (Rule Execution), then -while loading- it shows "Run a manually trigger rule" then it disappears!!
Any Clue??
Hi Ibrahim - Welcome to the Atlassian Community!
I believe the rule has to be created as a Manual trigger in order for it to be run manually. You can't just run any trigger that is created manually on an issue.
If it is not a Manual trigger already, then you should be able to copy the Rule, change the trigger to manual and then you should be able to see it.
Great
Thanks John for your quick response
I will try it and update you...
thanks a lot dear John
I actually worked just fine.
Yours,
Ibrahim
