Mapping issue with CSV import to update existing data
deb April 16, 2020 edited
I am trying to update story points for a project via the Admin csv import. Here is a sample of the csv:
issue key,Summary,story points
DWT-5,,5
DWT-1,,10
On the mapping screen the below happens:
csvissue.png Why aren't the fields listed separately for mapping?
Tony Rossiter
April 16, 2020
@deb
The import/update tool will require a value in the summary field.  Can you include it in the CSV and try again?  I expect that will fix it.
I will try it, but why is it required? According to the documentation example  for "Update existing issues" the summary entry can be empty. Here's the examples given (see row 3)
issue key,summary,votes,labels,labels
TT-1,Original summary,1,label1,label2
TT-1,,7,label-1,label-2
TT-1,Changed summary,,,
TT-2,Original summary 2,1,label-1,label-2
TT-2,,<<!clear!>>,<<!clear!>>,
deb April 16, 2020
Adding Summary value did not help:
Tony Rossiter
April 16, 2020
I can't honestly say.  I don't have any first-hand experience with this exact use case where you're updating fields for some records but not all and to get around the Summary requirement issue on most imports I just always include it.
Hope including the summary values fixes it :D
deb April 16, 2020
Thanks, but it did not help (see above). Hopefully someone will see this who has attempted an update like this.
