Match Custom Priority Field to Standard Jira Priority Field via Automation
Rachael Garbee
Good Morning,
I'd like to match a custom priority field we have in a project to the jira priority field in the project via automation. Would I do this using smart values?
Alexis Robert
Hi @Rachael Garbee ,
in this case I would suggest using the Advanced compare condition in Automation : https://support.atlassian.com/jira-software-cloud/docs/automation-conditions/#Automationconditions-Advancedcomparecondition
You should be able to use smart values to compare 2 fields, and trigger an action.
Let me know if this helps,
--Alexis
Rachael Garbee
Thanks, yes I believe I understand using the advanced compare but I'm not super experienced with using smart values and I get tripped up. Since one field is the jira priority and one field is a custom priority what smart values would I use to surface?
Alexis Robert
that's pretty easy, here's the smart values you can use :
  • {{issue.priority}} for the standard Jira priority field
  • {{issue.Custom Priority}} for your custom priority field (just replace "Custom Priority" with your custom field name)
--Alexis
Like • 2 people like this
León Gilhaus September 8, 2023
Hello @Alexis Robert ,
I also have the requirement that I want to match my individual fault class with the default priorities. This also worked with an automation.
However, I have a small problem. Namely, I use the JIRA Cloud Integration for Teams and every time a ticket is created, a notification is sent to the team in Teams. Now, the moment the ticket is created, the notification is sent first and then the automation for updating the priority starts. This leads to the fact that the correct priority is never displayed in the first notification in teams.
Do you have an idea how I can solve this?
