Hello community!
I need to know how many reworks were generated by the deploys of a given week.
I'm solving this through the "Linke Issue" Jira feature. Whenever a rework is identified on upstream, we analyze which activity originated it and then link the two activities through "Rework".
"Rework" is a type of issue linking that we created. In the Outward Description we have "is the rework for" - which we use from the "child" rework activity. In the Inward Description we have "rework in" - which we use in the "parent" activity that gave rise to a rework.
To search for the reworks list within a certain period, I'm using the following JQL:
project = ("Help Desk I (HOUSTON)") AND issuetype = Bug AND resolutiondate >= startOfWeek(-3) AND issueLinkType in ("is the rework for") ORDER BY resolutiondate ASC
But here I can only get the list of reworks. I want to know how I can combine a JQL that brings me the list of child items (reworks) and their respective source activities (parents).
Note: We don't use plugin (without scriptrunner for Jira please). I just want to solve this with JQL.
Hi @Dionei Piazza,
With standard JQL, you can only get a list of issues with links and export them to Excel for further processing. This works if you want to do a one-off analysis.
Standard JQL doesn't easily allow it, but you can find the results quickly using our professional indexing service: JQL Search Extensions
After you install the app, you can simply search:
issue in linkedIssuesOfQuery("project = ('Help Desk I (HOUSTON)') AND issuetype = Bug AND resolutiondate >= startOfWeek(-3)") OR project = ("Help Desk I (HOUSTON)") AND issuetype = Bug AND resolutiondate >= startOfWeek(-3) AND issueLinkType in ("is the rework for") ORDER BY resolutiondate ASC
Check out the documentation to see more examples.
I hope this helps!
Daniel
Jira does not natively provide a method to get what you want. You will need to execute multiple queries (i.e. use the output of the first query to build a second query) or write a program that uses the REST API to get the results.
Otherwise, you will need to use a third party app that can extend the Jira search functionality. Scriptrunner is just one such app.
