Message custom field (View) is not working when set default value
rbalamu2
Hi Team,
I created a message custom field (View) and tried to insert a default value using html text for font color in red as shown below.
<p><b><font color="#d04437">Review Approval should be updated by Review Leader only</font></b></p>
I put the above html text to default value and click set default button. When I try to view the default value it shows as below attachment.font.PNG
Kindly resolve this issue at the earliest.
abelalia87
April 26, 2023
Hi @rbalamu2 ,
Use this instead: Format Jira.
*{color:red} Review Approval should be updated by Review Leader {color}*
The default value will change when you view it again, just save the initial format.
rbalamu2
It worked like magic.
Rahini
Register here ⬇️
