Migrate Issues with Attachements - CSV File
Foxcliffe Hickory
Hello -
I'm trying to migrate issues via a CSV file from one Jira Cloud instance to another Jira Cloud instance. The attachments are not coming over. I know this is because the source and target instances are private, and that an API Token is needed. However, I'd like to know if there is a workaround for not having to use the API Token method, as it is cumbersome.
Is it possible to set one or both of the instances to Public, just to do the migration and have the attachments come over properly, then set back to private?
If this is possible, can someone explain the steps and settings needed to do this?
Thank you!
Angélica Luz
August 27, 2021
Hello @Foxcliffe Hickory,
I saw that you created another post related to this issue and the documentation below was mentioned:
Checking similar cases, I’m afraid to say that’s the only workaround for now.
If the site is public and then you change the permissions and close it again, the attachments won’t be accessible. It will only be accessible if no authentication is needed o the site where the attachments are stored.
Angélica
Foxcliffe Hickory
Thanks for the information, Angelica.
Like Angélica Luz likes this
Stefano Alessandrini September 30, 2021
I've the same problem.
Importing attachments into Jira Cloud using CSV External System Importer
did not worked for me...
Angélica Luz
October 1, 2021
Hi @Stefano Alessandrini,
I saw that you created a ticket with our support related to this issue. Your case is different because you are migrating from Jira Cloud to Data Center and the documentation has the steps to import attachment into Jira Cloud only.
Since you already have a ticket with our support, let's focus on the ticket to avoid any possible misunderstandings or miscommunication that may arise from discussing the same matter on two different platforms.
Angélica
FREE
