Migrating Attachements | API Token
Foxcliffe Hickory
When migrating issues from one Jira Cloud instance to another Jira Cloud instance, the attachments are not coming over with the issues. I believe an API Token is needed, however, the documentation on this is somewhat vague: https://support.atlassian.com/atlassian-account/docs/manage-api-tokens-for-your-atlassian-account/
Does anyone one a clear and easy to follow tutorial on how to add an API Token so that attachments get carried over during an issues migration?
Thanks.
Carlos Garcia Navarro
August 15, 2021
Foxcliffe Hickory
@Carlos Garcia NavarroApologies, I forgot to mention the migration was only for CSV file, not complete instance backup or migration. I'm sure it's easy when doing a complete system restore, but when just moving one project with multiple issues and attachments, it doesn't work automatically. There is mention of using an API Token to get the attachments over.
Thanks for any advice.
August 15, 2021
Hi @Foxcliffe Hickory , did you follow the steps to create the API token ( as described in the article you referred- https://support.atlassian.com/atlassian-account/docs/manage-api-tokens-for-your-atlassian-account/)?
You'll need that API token to include it in the csv that you're using to import the issues.
This other article has an example or how to use the API token that you've generated:
https://confluence.atlassian.com/cloudkb/importing-attachments-into-jira-cloud-using-csv-external-system-importer-966669960.html
Foxcliffe Hickory
Thank you for following up, Carlos! I will try in the information you've laid here.
FREE
