Migration Jira Server to Data Center
Deleted user November 14, 2022
We need to migrate a Jira SW server v6 to Data Center. Is it necessary to migrate first to jira server v8 and then to data center?
Laura
Rilwan Ahmed
November 14, 2022 edited
Hi @[deleted] ,
Support to Jira 6 was stopped long back by Atlassian. It is better you upgrade to latest version of Jira software at the earliest and then start the Server to Datacenter migration.
Please note: Atlassian does not provide support for instances on versions that have reached End of Life. The only exception is for assistance related to upgrading from your EOL version to a supported version.
For versions that are supported, you can raise issues via https://support.atlassian.com.
You can find the new version and their release notes in https://confluence.atlassian.com/jirasoftware/jira-software-release-notes-776821069.html and the Date for End of Support/Life for each presently supported versions in https://confluence.atlassian.com/support/atlassian-support-end-of-life-policy-201851003.html
Ganesh
Hi:
Could I have the clear migration steps to Jira DC from Jira Server.
A document or a video would be helpful.
Thanks in advance.
Ganesh.
Rilwan Ahmed
Hi @Ganesh ,
To migrate from Jira server to Jira DC, you need to get the license for Jira DC and apply it it the jira server. This will auto change your server to DC version.
Once you applied the license, you need to Set up your cluster.
Instructions are present in https://confluence.atlassian.com/adminjiraserver/migrate-from-server-to-data-center-993929572.html
Ganesh
@Rilwan Ahmed  Thanks for taking your time to writing to me.
Thanks for the instructions link. keep supporting us.
FREE
Register today
